Thread: Flash dash
Old 11-19-2004, 06:53 AM
PCC's Avatar
PCC PCC is offline
Hmmmmmmmm,
The layout has changed since DRB's photo's.
If anyone goes this way check that the bloody glove box fits well - notice its not installed in the photo
The AUI cluster is a straightforward fit into the dash. However a few mating problems with the chaser cluster and NC computer:
1. The tacho reads approx 500 rpm too high - who cares as you listen to the engine anyway; and
2. The water gauge is erratic - tried to fix with an additional diode, but got tired of getting to work anyway. Hence, a couple of new Stewart Warner gauges for x-mas (Symmetry issue).
Also the sppedo head died whitch EMP fixed (apparently common on AU's - bloody Fords)
PCC (Peter Craig)
Keep the sun shining
