Old 11-22-2004, 04:37 AM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Arrow
To begin with the vent piece of brass you describe is the standard
vent plate. The plastic "whistles" are supposed to prevent fuel from sloshing out vent tubes under hard G forces (cornering,braking and acceleration). I would say thatthey should be installed if you plan on such activities. It makes me curious about the metering blocks. Since the whistle tubes require a small brass rivet to hold them in place, they either left the hole unplugged, plugged it with the regular rivet(minus vent) or swapped metering blocks all together. I would personally suspect the latter since I've never had to remove a whistle to do any carb work. You can look at the metering block and determine if they were ever used with a whistle because of the mentioned rivet/hole.
WDZ
