Old 11-23-2004, 09:34 PM
jared1970 jared1970 is offline
10.25:1 .030 over 428
Edelbrock heads from Keith Craft with a valve job, some bowl work, and better valve springs
Rocker stand stud kit for Edelbrock heads
Rocker Shaft end supports from Precision Oil Pumps
Edelbrock Performer RPM intake
Edelbrock Water Pump
Jet Performance Stage 2 Holley 750, vacuum sec electric choke
Cam Research Hyd Flat tappet Lift .540 int., .565 exh., Adv. Dur. 291 Int., 295 Exh., Dur. @ .050 226 Int., 234 Exh., Lobe seperation 109.
D.U.I. custom distributor
3/8 hardened pushrods (got them for FREE!)
All the oil gally holes were drilled and tapped for plugs and I'm running adjustable rocker arms just in case I decide to switch to solid cam someday.
Oh, and about the Mercury valve covers... the adjusters on my rocker arms were hitting the breather baffles, so I can't use those valve covers now. Sucks, because I really wanted to use them. Borrowed my buddy's taller valve covers off his Tunnel Port, and used them to break the engine in. Oh, and I should mention this engine is going in my '70 Cougar, hence the desire to use the Mercury valve covers. I'm trying to chase down some aluminum valve covers with Cougar scripting on them, I've seen them in old Super Ford magazines. If anyone knows where I can find a set, let me know.
