  #30 (permalink)
Old 01-05-2005, 07:35 PM
bmcmillan bmcmillan is offline
Cobra Make, Engine: B&B non-donor, 496 Genesis SO (608 HPwith 9.4:1 CR), Tremec TKO, Currier 8.8
strictlypersonl
you'll end up with +1/2 degree at maximum (street) G force
I certainly don't want to be argumentative, but I have found that on a real racetrack in a front engined race car, anything less than about 2 1/2 degrees negative camber just won't get power to the ground and will heat up the outer edge of the outside rear tire. We used to start with 1 1/4 degrees static and go up from there while cornering.
The Nascar boys bend the straight axles 3/4 degrees negative.
Anyway, as Richard sez: "There's more than one way to skin a cat".
Brian
