Old 01-31-2005, 04:07 PM
JayBar's Avatar
JayBar JayBar is offline
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
Send a message via Yahoo to JayBar
I hate to drill holes in anything so I used double side tape, the good kind that you put chrome onto the body with.
I got two stainless steel washers as big as would fit. then mounted the mirror to them, using a flat head screw up from the bottom and an acron nut on top. The washer provided enough surface for the tape to work. Been on for two years so far.
And if a kid pulls on it and makes is loose just re-tape.
JayB
Jupiter, FL
