Old 02-05-2005, 05:24 PM
KrAzEcJ's Avatar
KrAzEcJ KrAzEcJ is offline
Cobra Make, Engine: Unique# 4279459
Send a message via ICQ to KrAzEcJ
Cobrashoch made a good point about a stock block is all you need. My weight comparison was not between a stock block and an aluminum block. It was between a hi performance iron block (A460)
M-6010-A460* 10.322" Deck Height
Cast iron block with 4-bolt main caps on journals 2, 3, and 4
Nodular iron main caps
Can be bored/stroked to produce 598 cu. in.
Siamese cylinder bores
Bore range from 4.360-4.600"
Wet sump oiling design
3.000" main journal diameter
Weighs approximately 290 lbs.
High-strength block for professional competition (Circle Track, Drag Racing)
And an aluminum block with "almost" the same specs {can be bored out further)
M-6010-A96* 10.320" Deck Height
Heavy duty, light weight alternative to cast iron
356-T7 cast aluminum block with 4-bolt, steel billet main caps
4.625" maximum bore size
Siamese cylinder bores, 6.500" long
Finished main bores for standard 3.000" crankshaft journal bearings
Uses M-6261-A460 roller cam bearings
Weighs approximately 179 lbs.
Available from Raceparts Distribution, Inc. (704) 892-8688
NOTE: Siamese blocks are solid casting between the cylinder bores. There are no water passages between them.This is done to increase the strength of the block.
So if your comparing a stock 429/460 block with an aluminum, like Cobrashoch said, theres not much difference
Unique # 4279459
