Old 02-18-2005, 01:56 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Ernie, The info will be on the website then. If you want to look at something before I could send you a PDF file.
Don
Here is some basic info on the car.
2005 HDR - Gransport Series Daytona Coupe Kit
Stage-1: Complete Roller Plus
BODY:-
Main Body w nose hinged & Latched, floor pan & front inner fenders installed.
Dash, (Not installed).
Body is produced from ISO-Resin in black Gel-coat.
Doors w/inner panels bonded and hinged w/interior door handles & actuation rods.
Bear Claw door latch & Catch’s.
Rear spoiler.
D.O.T Safety glass windshield.
Aircraft Polycarbonate rear window, side quarter window scoops & light covers.
Frame:
4130N Aircraft alloy chromoly main frame structure. Drilled & tapped for all lines.
4130N Suspension links throughout.
Teflon lined hardened steel Heim joints for all links.
Large Chrysler racing screw-in type ball joints in front suspension.
Front ¾” solid sway bar. (Because of the Satchel geometry, no rear bar is required.)
Custom fabricated front spindles. (NO FORD PARTS OR GEOMETRY IN HDR CARS!)
Complete custom Speedway Engineering full floating 9” style rear differential.
The Satchel Link rear suspension system. (Exclusive through HDR only by Mr. Terry Satchel.)
30 gal aluminum fuel tank.
Custom HDR 4-row dual pass aluminum radiator.
Custom HDR original style oil cooler.
Custom BRT Road Race steering rack w/collapsible steering safety shaft & GT wheel.
Motor & trans mounts.
Aerospace engineering front aluminum hubs.
Team - 3,__ 16” or 17” wheels w/polished spinners and Lug nut covers.
Dunlop GT-Qualifier tires.
QA-1 double adjustable shocks w/ springs.
Body rubber mounted to frame.
___ 2005 Price before shipping - $29,250.00
The new HDR Gransport model Daytona kit closely utilizes most of the same engineering, parts and extremely high end raw materials that are found in our standard high end turnkey models; obviously the frame itself had to be modified in order to make the car kit build-able. Our body is produced with one of the highest grade resin type available and is layered with a partial hand laid and partial chopper gun technique and reinforced with Cormat in strategic areas. Our body has been intentionally produced in black colored gel-coat in order to accentuate the fact that there is little to no body work needed to finalize the body to a show finish. Our body also has all of the ports obviously outlined from the mold itself so there’s no measuring guess work when cutting, drilling or riveting. All of the chassis parts, I.e. suspension links, brackets ect, are the very same used in our high end turnkey models as are all of the after market parts which ensures you that we can and will support these items for and through your cars production. It further insures you the absolute best names in GT car parts rather then_standard_stock geometry Ford or Chevy parts. HDR is also to our knowledge the only company who will warranty all of the chassis parts produced in-house for 3yrs or 36000 miles after the car is completed
p.s. The body mold for this car was pulled from the original #2299 before the last paint job. The mold was then squared front to back and side to side because #2299 was not dimensionally the same from side to side.
