Old 02-21-2005, 05:17 PM
Rick Parker's Avatar
It will depend greatly on which intake you are using. (carb base height in relation to top of distributor) You may find the bottom of the air filter housing will have to be raised or use a spacer between the carb and manifold to clear the distributor. If you know the length of the housing, just project the installed distance forward while using the carb top as a guide.
Rick
Rick
