Old 03-08-2005, 05:44 AM
ridelikehell ridelikehell is offline
Cobra Make, Engine: BRM #20, Ford 302, Holley 600dp
Send a message via ICQ to ridelikehell
I've got an almost identical setup as you, except with a Holley 600 instead of your Edelbrock; but same block and manifold.
That oval cleaner comes with a plastic spacer that you need to clear the distributor, but it does clear fine. The only question then, with the spacer in place, would be if you have enough clearance up top under the hood, which will depend obviously on the construction of your chassis.
What motor mounts are you using?
