Thread: Sidepipes
Old 04-09-2005, 05:14 PM
rblong rblong is offline
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
Standard 4 bolt flange from headers off engine to 4 bolt flange on collectors. You cannot see that connection since it is in engine bay. Then I had 4 inch collectors made and and Jim fabbed the side pipes to slide over collectors. He also supplied the turbo baffled and I drilled and mounted them inside side pipes. If you look close there is a stainless steel clamp I bought from a semi truck supply to use over slip connection. I fit the pipes up and then welded a mounting plate for the back. Took all to a local coating company and had ceramic coated. I ran around for several hours today and I love them. Time will tell but I think this is a great set up. Look in my gallery for pics as I was fitting.
I drilled a 1/2 inch hole in the end of the baffles to give it a little more SOUND, but you can play with them as you like. It is a matter of maybe 15 minutes to pull them and tune as you like. If you want to be REAL LOAD you could just take the whole baffle out.
Jim seems to be a great guy to work with.
Bruce
