04-21-2005, 06:13 PM
KY
Hey guys....just make one.....Take a piece of 1/8 or 1/4 each steel.....get a hole saw to match the diameter of your pipes and cut it out. Make a flange to match the header.....and bolt them together with a thick piece of something in between for flex. You can slip your sidepipe or header into the flange and weld on the inside....then grind down flush.
