Thread: Side Louvers
Old 05-29-2005, 01:12 PM
Yetiman's Avatar
Yetiman Yetiman is offline
Cobra Make, Engine: Arntz/SBC/Jag
If your going to epoxy them in, you need to thicken the epoxy. Epoxy alone won't be strong enough, and will run too much.
What you need to do is mix some 'wood flour' into the epoxy. The best source is if you have a palm sander with a dust collector, mix some of that extra fine saw dust in with the epoxy to thicken it. Besides thickening it and keeping the epoxy from running, it will make the joint much stronger.
I would drill a couple small holes in the pieces that will be attatching so as to hold better also.
Otherwise look into an epoxy product like PC-7 which may or may not be available where you are.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
