Thread: Roll Bars
Old 06-01-2005, 07:07 PM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default Did check with NASA
The guy, David Smith, is one of the technical guys and we swapped a couple of emails and he said I absolutely would be required to have roll bar protection for the passenger side so an instructor could ride along. I also sense from reading a bunch of threads that if I'm going to put this beast on the track, I should be thinking about as much practical protection as I can get.
The main thing is I don't want it to be permanent so I can take it out and retain the classic look of the car. As such, I'm hoping I can get something made that can be bolted to the floor where I can just take out the carpet, bolt it down, and then remove when I'm done. Maybe a tri-pod type set up. Chuck's name sounds familiar for some reason. Where is he located and is this his main business?
Thanks!
