Old 07-05-2005, 11:33 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
It appears that the LUCAS MGB panel rheostat will work on the Cobra. It is 12 volt, with the on/off and low to high voltage rheostat. Same flat sided metal key knob for the fluted plastic dash knob. Has four spade connectors and can be found for $25 to $35 vs the $125~ price. I have one on order and if it works, or if it does not, I will let you all know.
My current rheostat is "notchy" in that is does not smoothly go from dim to brite with small gradiants, it appears coarse in the adjustment and has seen better days. Once I get a replacment I will try to use contact cleaner on the rheostat to see if it would clean up a bit.
Thanks for the help.
And yes that search engine on the Cobra Restorer's website is an odd implementation.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
