Old 07-20-2005, 10:44 AM
flipper35's Avatar
flipper35 flipper35 is offline
Cobra Make, Engine: Shell Valley, Mopar thingy (small block of course)
Default Holley wierd noise
I decided that after sitting for years I should be putting new gaskets and "O" rings in the carb. Actually the jets and primary gasket were missing. Don't remember why, I forgot the carb was even at my parent's house.
Anyway, new rebuild kit and replace the power valve and secondary spring with the correct ones slap it on and: A noise like someone letting the air out of a balloon while pinching the neck. Sound varies with RPM. I checked the secondary spring houseing while it is on the car. Do I need to remove it and check something else? It starts good and seems to run OK, but I haven't driven it or set the idle yet.
Brent Dolphin
