Old 07-26-2005, 10:35 AM
wicked fast's Avatar
wicked fast wicked fast is offline
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Default Michael
Well here goes.
Used the Dupont ChromaBase for the color and
clear. It was very easy to mix and spray.
Spent 50 plus hours doing the body work,
4 half days primering and painting.
Borrowed a 6hp 175psi 30 gallon compressor
and a Hobby Air fresh air system.
100.00 for various sandpapers,
75.00 one gallon of Evercoat SlickSand primer-filler,
100.00 for filler-primer in spray cans,
30.00 for clear plastic for the garage,
129.00 Sharpe Finex 300 with 1.4 tip,
850.00 gallon of blue, primer-sealer, quart of white,
gallon of clear, polishes, bonnets, reducers, tape,
masking paper, and activators,
35.00 to build a wooden dolly for the frame-body,
25.00 for undercoating,
30.00 for buffer at Harbor Freight Tools.
I also figure another 100.00 for the small stuff.
Hope that helps. Email me if you need more info.
Good luck on the Hi-Tech, they are great cars.
Best,
wicked fast
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
