Old 08-05-2005, 02:49 AM
ffindling's Avatar
ffindling ffindling is offline
Cobra Make, Engine: Findling 001 - starting scratch build
Default 390 stroker....
I believe it is based on a .030 over 390 block which when combined with a 4.25"
crank would yield 444.5 CID. The crank
is a 2.2" journal for 6.7" BBC rods. This gives a rod length/stroke ratio of 1.576.
The combination is a bit undersquare, but
it shouldn't be a problem unless you want
something that will twist beyond 6,000.
Should make for a good torquey street
motor.
....Fred
