Thread: Throttle cable
Old 02-25-2006, 04:12 PM
leslie.files leslie.files is offline
Cobra Make, Engine: Excaliber body, Modified Custom frame
Check to see that the butterflies on your secondaries are not hitting on your intake. If you have adjusted everything else, maybe the holes in your intake are smaller than the b-flies on your carb. easy to check, run the linkage on your carb by hand, if it opens all the way easily than try adjusting the draw on the cable.
Tohmer
"Ask not what your country can do for you, but what you can do for your country" JFK
