When you said you purchased a Shelby housing, what pieces did you get?
I'm not certain what limited slip unit Shelby and/or Kirkham uses, maybe someone will post. Different brands and prices for the various designs.
The rest is Dana 44.
Parts you might need:
1. side housings, stub axles, bearings, flanges (expensive)
2. case should have two main caps inside with bolts (machined as a set)
3. Ring and Pinion (Precision Gear)
4. Posi unit, some brand/type ---------------------------------ANYONE KNOW what Shelby and Kirkham, pros and cons?-----------
5. Shims for side housings (unique to this diff)
6. Rear cover (drill your own vent hole and baffle, fill below fill hole)
7. Bearing kit for Pinion, shims, front input flange 1310 series (Upgrade necessary)
8. Bearing kit for stub axles (main caps)
9. Gaskets come with some of the other kits
May as well start worry'ing about the rear axles now as well, drop me an email and we can trade info and sources.
The prices vary wildly between sources!!!!
