Old 04-03-2006, 04:49 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
The stock manifold is going back on for rego it was only a a momentary distraction. I just wanted to bolt it up and see if the bonnet would shut. Looks like it'll all fit easily under the standard bonnet and hood scoop and the only giveaway will be the noise it makes (and possibly large black tyre marks behind it).
The wiring loom is progressing well. The dash is all done and I'm working on the steering column connections now. I've mounted two aluminium panels on the fire wall behind the dash and all the relays and the fuse box etc are attached to the panels. It makes it much easier to work on as you can pull the panel out and wire it up on the bench. Hope to post a couple of pics of them soon.
Now where can I get me one of those Mr Fusion thingies?...
Mike Murphy
Melbourne Australia
