Old 04-03-2006, 05:46 PM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Hi Poolw,
So far I just did the back. and it makes such a big difference. Below are the part #'s from Summit. For the rear the only thing you need to do is fab a 1" spacer to stop the coil from hitting something. Look for a prior post. Someone posted a great picture. The spacer went on the lower mount.
HAL-14-200 14" SPRING EACH $36.95 2 $73.90
HAL-DR8855B REAR SHOCK ALUM ADJ W/HDWE EA $168.69 2 $337.38
HAL-SS110SDM STUD MOUNT CONVERSION $32.99 2 $65.98
I will be ordering the the front coil-over conversion kit very soon. It is going to be my Spring project. From what I know they just bolt right in.
Here is the Summit Part number for the coil over conversion kit....HAL-MS1375
They also have another kit with different weight springs.
Hope that helps.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
