Old 04-07-2006, 04:21 AM
DAVID GAGNARD's Avatar
Tim;
Run an Edlebrock dual plane performer rpm intake and a drop base air cleaner and you can get a 3" air filter element and it should all fit nicely under the hood.......
If you can find a rear end from the 70's Versailles, it is a 9" with factory disc brakes and will bolt right in the Maverick, you'll have the 9" plus rear disc brakes, it's the correct width and the spring perches are in the exact location they need to be.........also the 1980 Granadas had a 9" and it's also the correct width and will bolt in, but has drum brakes.........
With the 351-W, you'll definetly have a "street sleeper", especially on a four door car........................
David
DAVID GAGNARD
