Old 04-11-2006, 06:22 PM
Dinobyte's Avatar
Dinobyte Dinobyte is offline
Cobra Make, Engine: Backdraft #395 from Vintage Motorsports; Valley Ford Specialist 487 FE with a TKO600
Originally Posted by Cashburn
It is not the transmission's dimensions, 'tis the shift linkage ... quite a difference
Have any other BDR owners installed Toploaders and figured out a workaround or shortcut to make this doable without all of the Linkage clearance issues? Also, is a Toploader longer than a Tremec 600? If so, where do you make up the difference in length? Do you push the transmission forward?
