Old 04-30-2006, 04:21 PM
d_ford's Avatar
d_ford d_ford is offline
Cobra Make, Engine: CSX4000, Shelby aluminum 496 ci FE
Default cooling fan not running
My cooling fan isn't running when the engine gets up to temperature. It ran ok when I first bought the car, but it hasn't worked the last couple of times I've had it out. I can use the fan switch on the dash and it works fine. I suspect it's probably the temp sensor in the lower radiator hose but I wanted to pick your brains before I order a new sensor to see if any of you have run into a similar problem that turned out to be something other than the sensor. I haven't looked but was wondering if the fan dash switch and the temp sensor both run the fan through the same fuse? Any ideas appreciated.
Doug
CSX4761
ERA #115 - sold
ERA #002 - sold
07 GT500
66 GT350 tribute
70 Mach 1
65 Comet gasser
