Old 05-08-2006, 10:58 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Figure out what diameter and length you need (1 3/4"?). Go to a good hardware store; they should have dowel pins.
Don't forget to loctite the cam bolt; I've seen them come out if you don't...it's not a pretty sight.
You should be able to tap it in while the cam is in the block...the worst that will happen is the rear frost plug will get knocked out.
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
