Old 05-13-2006, 02:47 PM
Jake's Avatar
Jake Jake is offline
Cobra Make, Engine: Superformance Cobra #1628, Coast Performance Stroker 427W Ford 520HP/535FT.TQ, Blue with white stripes
Default Trailer Size
I have a 25' Allsport by Interstate which is 20' with a 5' V-Nose. I have towed it with a Expedition with the 5.4 and it did get the job done. I would recomend getting air bags or a 3/4 ton or better vehicle if you are going to be doing a lot of towing. However if it is just day trips now and then you should be fine. I would recommend getting an equalizer weight distribution hitch system which will also help with sway. I would also go for the 20' as you will want the extra room and you will not notice the 2' when you are towing.
My 2 cents, Jake
