Old 05-16-2006, 12:10 PM
cobraduke cobraduke is offline
Cobra Make, Engine: SOLD Excalibur, '94-'95 5.0 EFI, Edelbrock heads, E303 cam, 1.7RR, Cobra intake, 24lb injectors, 93 cobra ECU, 65mm TB, hi flow cats.
Default Help ID Aluminum Heads
Hi,
Bought a cobra with 5.0 EFI engine in it. It has had some mods, but no paperwork or oral history. It has aluminum heads which appear to have stock configuration exhaust ports. The only markings I can see (haven't pulled valve cover yet) is about a 1 to 1.5 inch cast raised circle with a cast raised solid block style letter "E" inside. This is located below the number three exhaust port slightly toward number four port (driver's side reference).
Anybody got an idea as to what they are?
Thanks,
Mike
