Old 05-17-2006, 06:34 PM
cobraduke cobraduke is offline
Cobra Make, Engine: SOLD Excalibur, '94-'95 5.0 EFI, Edelbrock heads, E303 cam, 1.7RR, Cobra intake, 24lb injectors, 93 cobra ECU, 65mm TB, hi flow cats.
Default Edelbrock ID Markings
Larry,
Hit it on the head (no pun intended). According to Edelbrock tech: that is a smog number, it covers all their related smog certified heads. No way to cross to a particular part number and no part numbers are placed on the heads by Edelbrock. They can only be ID'd by physical exam. Unless they are removed from the block, can not tell if 2.02's or 1.90's (not going to happen any time soon). I will be able to narrow possible part numbers when I pull a valve cover to see if pedestal or stud rockers (probably in two weeks).
Best guess is still the 60379's. (1.90's, with pedestal mounts, smog, Performer).
Thanks for the help,
Mike
