Thread: air cleaner
Old 06-10-2006, 09:14 AM
pmfranke's Avatar
pmfranke pmfranke is offline
Cobra Make, Engine: B&B 351/402 Fi roller everything
i have had many problems finding any air cleaner to fit.figure out what intake manifold and carb you want and before you buy ask c/c members with a bandb if it will work. I have an edelbrock fuel injection,air gap manifold, 351.the only air cleaner that would work is the edelbrock pro flo tri anglular one.i still had to trim a half inch off the base plate.i had only 3.23" of clearance total height , also some sensors ,throtle linkage and only 9 1/2" of width. when you buy make sure you can return it !!!!!!!! good luck.Peter
the older i get the faster i was.
