Old 06-30-2006, 06:47 AM
jetlag jetlag is offline
Cobra Make, Engine: scratch built aluminum chassis/bb
Pat-Sounds like you're on the right track. I temporary clamp the rack untill everything else is done,including caster/camber adjustment. With chassis at ride height,front tires on turn-tables,no front coilovers, run the suspension thru full travel and check for bump-steer with a dial indicator. At this point you may be amazed at how small a rack position correction will make everything 170MPH purfect !
