Old 07-02-2006, 10:28 AM
mj_duell mj_duell is offline
Send a message via AIM to mj_duell
Originally Posted by steve meltzer
I've been told that one can replace the rear main seal on a 427 by just R&Ring the pan. Is this true on our Kirkhams, or does one need to pull the engine out, or at least the tranny, bellhouseing and flywheel? thanx steve
Yes, It is true and it is not fun. Are you sure it is the rear main? I went through this last year and I was sure it was the rear main. After replacing the seal it was still leaking. Turned out to be a galley plug. Trust me on this, pull everything including the fly wheel and save yourself some grief. It could be the cam seal or the oil galley plugs on the FE's. You will have an easier time with the rear main either way.
--Mike / Turn Ten Racing, Inc.
