Jim,
Check out the second photo in my gallery--Yeh, I know its a 32 5 window ford but, I built the headers and side pipes as if it was a 32 Cobra---see the hole in the frame hole by the collector? That is where the O2 sensor comes thru for the FAST system--Can't see it--proves that it is hardly noticeable!!!!
Anyway, if you are going to run a carb you will only need the sensor while you are tuning it--you can weld in a bung and then put a plug it in
Jerry
