Old 07-19-2006, 11:49 AM
jeffko's Avatar
jeffko jeffko is offline
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
Good post Mark. This is too serious an issue to ridicule you about. We'll save it for later.
Although I have an extinguisher, I also had some potential problems with fuel delivery that Jerry pointed out. I had a fuel filter in the engine compartment that was more designed for low pressure before the pump rather than the 12psi after the pump as I had it.
I have a question about the cut off switches. I have one, but if the engine is still running doesn't the alternator power the system even if you used the cutoff?
Tis better to burn out than to fade away. So "Lite 'Em Up!"
