Old 08-01-2006, 05:50 AM
cameron02 cameron02 is offline
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
Hi Stephen,
My car is now registered and back in my garage. As you know I have the same motor.
I am running an after market pod filter. Cold air intake, it sits behing the headlight. No problems with emmissions.
You can come over and check the fuel lines. One in, one out and the plastic charcoal canister line is right next to them. I put the canister in the boot with a vent tube popping out above the rear axle. The Au canister also has a plug for some wiring. I used the original wiring so no probs, not sure if aftermarket wiring would cover that?
Feel free to come over and gave a look
Cameron
