Thread: cfm
Old 08-26-2006, 05:07 AM
nanard289 nanard289 is offline
Cobra Make, Engine: Cobra Daytona (from USR) 302RDI Yates headed + Weber induction
Originally Posted by 347
What is the CFM rating a single 44 idf weber?
My 347 has a 650dp, rpm air gap, 10.1 comp, 238/248@.050 solid flat tappet, 4.1 rear ,tremec, weekend cruiser.
If I was to change the 650dp over to twin 44idf's would I increase torque? hp? Or is it not worth the trouble?
Weber CFM depends mainly of your ventury size (335 cfm for my 48IDF with 42mm venturis). Not sur that a Weber change will increase torque at low rpm significantly. Usually, Weber advantages are mainly between the middle to top end (according to your camshaft characteristics, I believe that expected Weber benefit will be between 4000 to 6500+ rpm). However, a 44IDF works well for a 289/302 engine but for a 347cid I think that a 48IDF with 40mm ventury will be more efficient.
Everybody agree that a good exhaust collector have to be designed with each pipe in the same length to be efficient. I believe that this rule is also applicable to the inlet manifold
