Old 08-28-2006, 05:25 PM
chas427fe chas427fe is offline
Cobra Make, Engine: B&B, 428 FE, toploader
Dave, thanks for the help. I am getting closer. I have a small oil leak at the intake manifold to fix, change the oil pan because I put on a Canton while I had it out, trouble is I only have 1 3/4" ground clearance. I am going to put the stock one back on because it is 3/4" shorter. I also need to put a larger battery cable on and I will be on the road.
