Old 10-28-2006, 05:39 PM
kmarccoco kmarccoco is offline
Cobra Make, Engine: ERA
Default strange compression readings
my new 428(2k miles) has been idleing a bit strange for a while now.
i conducted a compression check and here are the readings.
cylinders 1-4 180psi
cylinders
5) 165 dry 175 wet
6) 175
7) 165
8) 165.
i only tested number 5 with a leak down. will do 6-7-8 with iol later. but i expect the same reading as #5.
why the lower reading on drivers side? what should new cylinders read?
my mech said he is going to r/r engine and look into it. will also change cam from 108 to 110. anyone have any input???
