Old 11-09-2006, 06:38 PM
Hall1836 Hall1836 is offline
Cobra Make, Engine: Superformance 351/427 stroker
Default Carb cars what fuel pump are you running..
Had a Holley blue way to noisey, some people said the carter was good. I got the Carter and it only had inlet/outlet of 5/16, they were part of the pump and couldn't be changed to 3/8 inch which I have on both sides of the pump. Now have a small, Mr. gasket "micro" but it looks like it is only putting out 3lbs.(supposd to be 4-7 lbs. according to paperwork). Haven't had a chance to thrash the car, not registered yet, to see if the pressure will be maintained at high RPM. What is everyone else using? Would have like to have just used the mechanical pump but block is 1990 I don't feel like pulling the timing cover and all that's involved.
