Old 11-22-2006, 01:13 AM
stephen low's Avatar
stephen low stephen low is offline
Thanks Mike but I did get the tri-wire exhaust system that is run standard on this motor and there is no way in heaven that these would have come close to fitting. I would presume there is something similar for the windsors but beyond the aftermarket huggers I haven't seen a similr beast.
If I have to do a cut and shut I may as well use my standard pipes which came with the O2 sensors in place and cats!!
It was just that the RMC and G Force kits looked the same that I took this punt, and clearly they are very close given some of the clearances I have but not just enough.
Given your experiences building these bits, is it terribly difficult for a beginner, or just time consuming? If the latter I am all ears as I have the time if not access to the equipment at the moment!
Let me know.
slowy
