Old 11-25-2006, 03:04 PM
Tony Radford's Avatar
Tony Radford Tony Radford is offline
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Thanks guys. I found some at a local auto parts store (actual fuel hose). It was $1.75/inch. The hose that came on the car was a couple of inches too short. I've been able to make it work by centering it on the two necks and clamping it down tight. At least it came loose at the top as opposed to the tank. I've been smelling gas for months, thinking it was a rich carb setting. I noticed gas dripping from the back end of the car and upon investigation, saw that the filler hose was completely disconnected from the fuel filler neck. I guess gas has been sloshing out on hard cornering. I just took her out after replacing the hose and smelled no gas for the first time in ages.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
