Old 11-26-2006, 06:24 AM
CHRIS DAMSCH's Avatar
CHRIS DAMSCH CHRIS DAMSCH is offline
Cobra Make, Engine: SPF 1454
I just had this problem in July. Same symptoms: Lot's of white smoke out of passenger side pipe, water shooting out of the plug hole, hydraulic lock also. I tried the intake gasket 3 times then took the head off to discover the problem. Ended being the worst problem... Cracked block between the water passage and cylinder wall. My motor had a 1969 block.
Hopefully you just have a gasket problem.
CHRIS
