Old 01-18-2007, 04:43 PM
Mike Hausner Mike Hausner is offline
Club Cobra Member
Cobra Make, Engine: CLASSIC ROADSTERS 427 with a FORD 5.0 bored and stroked to 331cid, BRODIX alum heads, roller rockers, B303 cam.
Fasterpatric,
I made my steering column using the turn signal head from a '65 CORVAIR. I also used the steering shaft from the 'VAIR and mated it to a CHEVETTE lower half steering shaft. The 'VAIR shaft fitts inside the CHEVETTE lower shaft so I could adjust the length. I then cross drilled the two & bloted them together. I used a 1-1/2" steel tube for the housing.
There's a little more to it than that. E-mail me if you want more info.
