Old 01-19-2007, 05:55 PM
Luke Gillett Luke Gillett is offline
Cobra Make, Engine: Classic Revival (CR3204) 6ltr s/c, T56 6spd
Hi Slow427,
The front rotors are 298mm, which is only slightly larger than the old Jag rotors (280 or 285mm???). The calipers are a 2 piston PBR caliper which looks very much like the ones used on the VZ Commodores. One of the benefits of this setup is that if I choose (and my wheel size choice lets me!), I can go up to a 330mm rotor with out too much heart ache. I will only need to fabricate a new caliper bracket.
One of the things which surprised me was the weight of the Jag calipers. The PBR calipers are about the same size but only half the weight.
I can dig out the models numbers etc. if you like.
Regards,
Luke.....
