Old 01-23-2007, 03:38 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Guys, You're right, without a doubt. I was bummed due to my ignorance of the 2V heads. I thought that meant that the engine was destined to be Dad's station wagon propulsion. I was obviously wrong, thanks to all the great info I got from you guys and so many others. My plans for the Cleveland are fairly short term - one day I still want an FE. Until then, I'll be running the Cleveland. I'm pulling it out later this week in order to prep the engine bay and swap out the automatic for a stick. Mr. Mustang has graciously offered to ID the block and heads for me to see exactly what it is I'm dealing with. (Thanks again, Bill) The biggest hurdle I see is finding a Contemporary pedal box that has a clutch pedal. Any ideas, guys? My gas pedal is seperate, not in the same box - I need to find an overhead pedal box with a brake and clutch pedal. Any ideas? This is by far my biggest concern on the project.
After I pull the engine I'll take off the oil pan, timing cover and intake, and try to determing as best I can what I have. I don't want to spend a alot on this thing, seeing that it's not my long term engine. I may throw a cam in it and a new carb, that's about it. Anything you guys think I should do while I'm in there that won't cost a bunch of money? It has good oil pressure now, should I throw in a oil pump anyway, or is that a waste of money? Are there significantly better pumps out there than Ford put in? The rear main doesn't appear to be leaking - I'm inclined to let it be. Any other quick ideas while I have it out? Again, thanks for all the input. It takes us old Chevy guys more time to learn the Ford way.
