Old 02-13-2007, 07:13 AM
RACER X #99's Avatar
RACER X #99 RACER X #99 is offline
I have a 12 V cooling fan mounted in the trunk that keeps the inboard Wilwood brakes cool and after 12 years of open tracking the seals are original.
I also have remote brake bleeding lines attached to the rear frame. Two per side for the Wilwood calipers. I don't have to even jack up the rear to bleed brakes.
Without the fan my brakes would overheat in 10 minutes with the fan I have run for an hour open tracking without loss of the rear brakes.
BTW the front brakes are 6 piston Wilwood Superlights with 12.19 rotors and cooling ducts.
You can't go fast on a roadcourse without good brakes.
SAAC member and supporter
Club Cranky charter member
