Old 03-05-2007, 04:51 AM
strictlypersonl strictlypersonl is offline
I've seen some abnormal wear and/or squeaking at the bottom connection of the front shock so I'd recommend keeping it lubed. Look around for spray-can grease or just cover both sides of the joint with standard or silicone grease.
It's not necessary to lube the bottom or top of the Jag-based suspension's shocks except maybe a little rubber lube.
