Old 03-22-2007, 01:30 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by flwolfman
Barry, what has to be done to a 391 trunk crank other than the reducing the snout and cutting a new keyway? Thanks, Jim
I think you have to cut the flywheel flange as well, because it is thicker, and to do it right, I think you also need to trim the counter weights, because they are bigger on the 391 crank, and too heavy.
I run a cast "390" crank in mine, some 427's came with cast cranks, as mine was an original replacement short block with a cast crank from Ford. I've heard that drag racers preferred them over the steel ones, because they were lighter, i.e. faster, and still good for 700hp.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
