Old 04-22-2007, 04:12 PM
CWizard CWizard is offline
Cobra Make, Engine: SPF, 418 Stroker
Default 351W Cam/Lifter Combo
I have a 351W stroked to 418 ci and am considering replacing the lifters. It is a pre-roller 1974 block, and currently has a Comp Cams reduced base circle cam along with their retro-fit spider/dogbones lifter retainer setup. The lifters are basically stock Ford hydraulic rollers (Comp PN 851), which are becoming increasingly noisy. I'm considering Crane's link bar lifters, PN 36532. Crane tech support says these lifters will work fine with my small base circle cam, but I'd appreciate some independent confirmation. Has anyone out there used these Crane roller lifters in a Windsor with a small circle roller cam, or do you know for sure if they will work?
Many thanks!
