Old 05-16-2007, 07:16 PM
Murphy's Avatar
Murphy Murphy is offline
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default Are the rear calipers ford disc brakes circa 1980's?
If you have the 80's style calipers on the rear like the kind out of a lincoln versailes or early vintage continental you must adjust the caliper piston by rotating it (it screws in and out, piston has threads) until it just causes a slight drag on the pads against the rotors. It's an odd system because of the parking brake. It would take a long time to get a pedal with a manual bleed if you do not adjustment first.
