Thread: Two Questions
Old 05-26-2007, 07:05 PM
FFRBob FFRBob is offline
Cobra Make, Engine: Factory Five MK3, 390 FE, Toploader
Stewart transport is constantly running several trucks across the US carrying Factory Fives. I bet you could work something out with them:
http://www.stewarttransport.com/
The 1965 title will not carry over to California. The great psychotic socialist beaucracy of Kaleefornia requires that you re-title your car as the actual year it was finished. If you have a block that is pre-1974, I believe, but could be wrong, that you can register it as a standard SPCN, but you'll have to go to the smog BAR station every two years so they can look to see if you have a pre-1974 block. It would be easier to re-title it using the SB100 process, but you'll have to wait until January to do so. All the allotted SB100 numbers are gone for the year. Do a search on SB100 here or on ffcobra.com for more info. I don't advise that you attempt to register it as a 1965, it will bite you in the butt.
